Newbie after some advice
Recently bought myself a 2005 520d m sport and after reading a few threads on here about common problems and things to look out for I decided to check my coolant temp, my car is running at 75 degrees so it seems the stats need changing and I also want to change the oil separator could anyone confirm these are the right part numbers
Thermostat 11517805811
Egr stat 11717787870
Yellow o ring 11532248435
Separator 11127799367
Also what's the procedure for bleeding the coolant system after replacing both the stats? And is there anything untoward about changing the stats or are they reasonably straight forward.
https://5series.net/forums/topic/114...e__hl__coolant
Welcome Newbie - it's easy to "search" the forum for many basic service questions.
Cheers! I know it's easy to "search" as I'd already seen that thread but was unsure if different models had different procedures as it was for a completely different engine.
