New TSB on dead batery
My Ride: 545i Mystic Blue/Black Leather Type 124 Wheels
SIB 61 12 05
Dead Battery Caused By MPM
MODEL
E60/E61 (5 Series), E63/E64 (6 Series) produced up to September 2005
CAUSE
An accessory plugged into the cigar lighter / power supply causes a back-feed of voltage into the vehicle electrical system when the ignition is switched off. This causes the MPM (Micro Power Module) to stay awake, and the vehicle battery to discharge.
Energy diagnosis identifies the MPM as the "sleep mode preventer".
CORRECTION
In case of customer complaint, verify that the customer uses the power supply for an accessory with an internal battery (cell phone with charger, MP3 player, radio equipment etc.) and that he leaves the accessory plugged in when the car is switched off.
To avoid a recurrence of the problem, reprogram the vehicle using CIP19.1
MODEL
CAUSE
CORRECTION
Site Founders
Direct link:
http://www.bmwtis.com/tsb/bulletins/bullet...mp/B611205g.htm
So it would seem there are CIP versions newer than 19.01 and 19.02...
Lenniz
01-10-2016 03:37 PM
Kbc
07-31-2015 10:07 PM
