New Plugs, New SES Codes...
My Ride: 2006 530i
i really appreciate the input. i promise i never went near that side of the engine except to remove the airduct on that side. i saw a post on the e90 forums regarding this, and someone needed to have their ecm reflashed after he did his plugs (dont know if this is what the service manager was referring to)
i also never turned the car on until everything was back together.
interestingly,the ses light came on about 700miles after i finished the work. it came on after i decided to use a bottle of techron, so maybe the ses light is due to debris? the abnormal rpm behavior happened right after the work was done though, so maybe they arent related?
My Ride: 2006 530i
the light has been on for a day (since adding the techron), and now it's gone. i'm really starting to think it was debris. as for the rpm acting up, i'll tap the idle control valve and check out anything else you guys recommend. thanks again
My Ride: 2006 BMW 550i
my mechanic told me the v8 engines use the valvetronic to adjust the idle. i never noticed a idle control valve on the intake either.
My Ride: 2006 530i
that's a good point. i cannot seem to find it in any diagrams (N52 engine), but there definitely is a valvetronic motor.
My Ride: 2005 530i, Premium Package, Grey Leather, Rear Euro Reflectors
06 530i 109k
Just changed my plugs with OEM NGKs, also did the valve cover gasket. As soon as I started it up, the RPMS go up to about 1100, then drop down pretty low to 300, then act normal. this never happened prior to changing the plugs and gasket.
now i have a SES shooting out p0174 and p0171 for system bank too lean. does my ECM need to be reflashed in order to adjust to the new spark plugs? perhaps i over-tightened the plugs themselves? any ideas??
