New owner, can someone help me identify this part?
Old Nov 17, 2014 | 07:35 AM
straight6's Avatar
My Ride: 2007 BMW 550i
Default New owner, can someone help me identify this part?
I just recently picked up a 2007 550i. Coming from the Lexus Forum, it's my first time owning a European. I have to say I'm happy with the performance and handling. Just hope that maintenance will be just as easy as the Japanese.
Anyway, looking at the engine, I noticed on the front of the engine , passenger side a broken hose. Can someone tell me what this is for and if its an assembly I need to get or just cut and reconnect it?
Attached Thumbnails New owner, can someone help me identify this part?-image.jpg
Old Nov 17, 2014 | 07:37 AM
straight6's Avatar
Another pic, sorry I'm working off my ipad
Old Nov 17, 2014 | 07:39 AM
straight6's Avatar
Last one. Hope this helps
Old Nov 17, 2014 | 09:55 AM
dingolfing's Avatar
My Ride: 2008 550i
I believe that is a vacuum line for the exhaust muffler flap. I'm guessing you have a non-sport 550i? Because the M-sport versions just have that line connection capped off, since the sport exhaust does not use the flap.
Just cut it and reconnect, you should be fine.
Old Nov 17, 2014 | 10:06 AM
BrandonSS's Avatar
My Ride: Alpine White 550i M Sport
IIRC the 07 and below sports do utilize the vacuum valve. The 08 m-sport however, redesigned the exhaust and omitted the valve in favor of a more open, freer flowing design.
Old Nov 17, 2014 | 10:12 AM
dingolfing's Avatar
My Ride: 2008 550i
Makes sense, probably part of the LCI redesign. Is the noise change noticeable when the flap opens?
Old Nov 17, 2014 | 11:49 AM
straight6's Avatar
Yes the 550 (i think) is base. What's LCI? also, whats should i expect once i get this reconnected?
Thanks for the feedback. I'll work on it this weekend when i get back.
Old Nov 17, 2014 | 11:55 AM
twh's Avatar
twh
My Ride: 2006 BMW 530xi 6MT
Engine: N52
Life Cycle Improvement
Basically a freshening up of the model some years after initial introduction
Old Nov 17, 2014 | 01:40 PM
westsidebalto's Avatar
My Ride: Sold: 545i, sport package, cold weather, 6MT
Engine: N62
Pretty sure it's going to get quieter at low speeds and initial warmup. I disabled my vacuum flap in the trunk (there's a whole thread on how to do that), so that the exhaust is louder upon startup.
Old Nov 17, 2014 | 02:43 PM
dingolfing's Avatar
My Ride: 2008 550i
Your vacuum pump is leaking oil too, which is a very common problem on our V8s, not too important to fix as long as it is a slow leak.
The old rubber seal shrinks and they are very hard to find, so I fixed mine with a tube of RTV gasket maker sealant.
