New member - Rebuilding an 08 535xi
My Ride: E60 535xi, E90M3, E92M3
Hi guys, I figured I'd post a bit of an introduction. My name is Anthony and I'm also a BMW enthusiast. I currently have an E92 M3 that pretty much sits in the garage. I recently found a salvage 2008 535xi with the M sport package, which will be perfect since I can drive it year round. So, I'm in the process of rebuilding it. (Currently looking for parts)
The damage isn't bad (I've worked on worse)This is a fairly straight forward rebuild.
Doesn't look too bad. Hopefully the radiator support is still straight? Shouldn't take too much to get this fixed if you're handy with a bit of body work and slight aligning. Awesome E92 M3!
Thanks, It's very minor. lower control arm, shock, and bang out a piece behind the headlight.
New headlight, bumper.. and fender.. and a few misc. little pieces that were damaged in the process and its good.
I don't do any bodywork, but I'm pretty mechanically inclined. A friend owns a body shop and said he'd come over one night and align everything for me. Then it's just the salvage inspection.
I'm thinking of doing the M5 front bumper.
My wife wants me to sell the M3.. I just can't.
My Ride: 2006 BMW 530xi 6MT
Engine: N52
Yup, that's pretty much it. No other damage at all. Gotta remember, in Canada BMW parts are extremely expensive. Bodyshops buy from the dealers so a quote to repair doesn't take much to reach a high enough value where they'd consider writing it off.
From my experience, insurance companies up here (in alberta anyway) don't really try screwing you over when you have a claim. I've seen cases where there was even less damage. They weigh out the odds.
Total cost of claim.
ie:
$1500 for rental
$10,000 for repair
$3,000 for "additional repair"
2 months waiting for parts from various sources.
misc..etc etc..
Then they calculate what they can sell the car for as is at auction vs time/money. Also, it's possible that you can have full replacement insurance (any accident with X% damage will be written off and paid out for what the owner paid. (This type of insurance costs extra)
ie:
$1500 for rental
$10,000 for repair
misc..etc etc..
Very interesting, Great info!
ie:
$1500 for rental
$10,000 for repair
misc..etc etc..
ie:
$1500 for rental
$10,000 for repair
misc..etc etc..
My Ride: 530i
Engine: M54
You may already be aware of this, but just in case you aren't:
The entire front structure of the E60 is cold-bonded and riveted aluminum. If there is any damage to any of the structural components forward of the firewall, they must be replaced. i.e. there is no 'pulling' if you measure the front rails and they're out of spec, even a small amount (1 to 2mm). If you measure that left front rail and its over or in, by any amount, you're replacing that rail. obviously if you have structural damage that isnt repaired properly, the car isn't going to drive straight and none of your body panels will line up.
apologies if you already knew this, but just in case i thought id throw it out there. the first thing id do before i ordered the first part on that car is get it up on a bench and measure it just to be certain.
good luck with the car.
Just a bit of an update.
Friday April 25th, more parts arrived. The headlight and fender both came in (both OEM)
My bodyguy is coming over on saturday to straighten out the mounting part behind the headlight. He's a journeyman and up until christmas, has owned his body shop for many many years. He retired and sold it to a ford dealer. Anyway, he's coming over with his tools to straighten out the only lightly bent piece. I'll take some pictures of this and show the process. I should have the fender and headlight on/aligned/mounted tomorrow.
Just waiting on suspension parts and the Front bumper.
I'm not sure if I'm wanting to go with the stock Msport bumper, or maybe go with an aftermarket M5 style front bumper.
My Ride: 530i
Engine: M54
RealOEM.com * BMW E60 530i WHEELHOUSE/ENGINE SUPPORT
It's cold bonded and riveted aluminum. I don't know how bad off yours is, but I have seen what the repair attempts look like, and they're not good. It only takes a couple of whacks with a body hammer to cause it to completely split in two. Again, these panels are all bonded aluminum and should only be replaced in a damage situation.
Not trying to give you a hard time, but it's very easy to get in over your head when you're talking about structural repairs on an E60. Last year I saw a car where someone tried to repair the very panel you're describing. They ended up sending the car to BMW for a full right apron replacement to the tune of $8000, because the failed repair attempt not only trashed the baffle panel but the mating seam where the baffle meets the apron.
Good luck with your project.
