New to BMW - Many malfunctions in short timeframe. NEED HELP!
My Ride: '07 550i
Hey I'll start with saying I'm new to the BMW family and to this forum. I have been looking at this forum for abouta week so I apologize if I didn't catch one with the solution I need. I recently bought a 2007 550i and a few lights have come on in the past couple days.
1. It started on my way from San Diego to LA this weekend. On the highway the "Driving Control System failure" light along with the "Brake" service light. I took an exit and turned my car off for a period of time and turned it back on and didn't see the light till later that night omw back home from LA. When I got home I turned the car off and haven't seen the lights again since.
2. This morning omw to work I got a tire pressure warning tellin me my tire was low or flat in the front passenger side. I get out to look and everything is fine.. I checked psi for all of the tires and they're all the same.
(P.S. While in LA I hit a curb on front passenger side and bumped the bottom of my bumper tire so there is a small gash on the tire wall I might have cause, but no leaking air.)
3. Omw home from work today I got a "Parking Assist" failure notification on iDrive but have never had a problem with parking assist before... It ended up working again when I got home.
It seems these problems are all intermittent and all took place within a short timeframe, so this leads me to believe that this is an electrical problem. Any suggestions?
I also have an appointment for inspection with BMW on Thursday to map out all problems the dealer didn't catch or let me know about. Thank you in advance for the help.
What you may learn after the inspection that the situation is caused by a failing battery (No.1) or a failing alternator. Most likely the battery. If the battery drops below 14 volts, every computer module in the car gets nervous and shuts down causing warnings.
My Ride: BMW 530xiT (E61)
Regardless of how this shakes out, you should dig into getting INPA and ISTA installed so you can read the stored codes and perform some of your own diagnostics. You'll save yourself a boatload of lettuce in the long run if you can troubleshoot on your own.
My Ride: 2007 550i Sport PKG
Thank you for replying
Good looking on replying!! What you guys said makes sense to me so I'll look into getting the battery and alternator tested. I'll keep this thread posted and post some pics after I get my car back and get done detailing it. Looking to add more to it I'm open to suggestions
viper1213
08-19-2015 09:56 AM
