New to bmw/forum.. CPO won't cover Radio causing High Battery Drain... starter advice
My Ride: 2010 BMW 528XI, 1954 Oldsmobile Super 88 324cui
Model Year: 2010
the part number i pulled out of my car was
9196762-01
It's built by Visteon
PN# CP8KAF-18C852-LF
Pulling the radio out is easy, a few trim pieces and being slow/cautious you can do the job yourself.
The CIC unit is a good upgrade, member changing the radio station? that 3-4 second pause? for Dramatics?... I hated it... CIC is instantaneous as it should be.
IMO CIC makes the car what it should have been and what it was in the late 2010 run.
9196762-01
9196762-01
9196762-01
So I am clear, the CIC is the newest version correct? With the CCC version being the one between the M-ask and new?
Watching the videos last night and experience I do have, I know I can replace the unit myself, but not the programming... which is probably the solution that I will follow.
This morning, no battery drain warning, which is good news (I got the warning 8 hours after on a brand new battery on the weekend).
For your upgrade, Did you go the ebay parts route, or buy the kit?
Again thank you so much for your help with this...
Awest91
09-17-2022 11:05 PM
DavaiLave
08-02-2022 02:16 AM
