New Airbag Service Bulletin
SI B 72 05 06
Safety Restraint Systems February 2006 Technical Service
SUBJECT
Airbag Warning Illuminated, FC 9B2D in SFZ
MODEL
E60/E61 (5 Series)
Vehicles produced up to September 2005
SITUATION
The airbag warning lamp (AWL) is illuminated, and fault code 9B2D is stored in the SFZ (Vehicle Center Satellite).
CAUSE
Safety Battery Terminal (SBK) corroded.
CORRECTION
Using DISPlus/GT1, follow the diagnosis test plan. The primary cause is likely to be a corroded SBK.
Check SBK for corrosion. If corrosion is present, replace the SBK (do not replace the SFZ) and check vehicle for leaks - refer to SM B61 210 04 (E60 (5 Series) Various Electrical Problems Caused by Water Ingress).
PARTS INFORMATION
Part Number
Description
Quantity
Refer to EPC
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Defect Code Refer to KSD
Labor Operation: Refer to KSD
Labor Allowance: Refer to KSD
SUBJECT
MODEL
E60/E61 (5 Series)
SITUATION
CAUSE
CORRECTION
PARTS INFORMATION
Part Number
Description
Quantity
Refer to EPC
Humm are they suppose to check this or worry only if your air bag light goes off?
Thanks for sharing this info, cobradav.
I have had no such problem, atleast yet.
umnitza
11-25-2015 11:10 AM
Bogdan7
09-23-2015 11:40 AM
