Need some help - replaced CCC, no sound (probably needs coded) - need some guidance
My Ride: 2007 550i
Greetings all!
This is probably super simple for some of you, but here is the deal:
1) Well, my 2007 E60 had the CCC go out
- Basically I had sound from the key, door, seatbelt, etc, but it just kept rebooting and no display...
2) I decided to purchase a unit on Ebay, and once installed it powers up and works well (nav shows, etc) - but I have no sound
One thing I noticed is it doesn't allow me to configure the L7 logic (it doesn't know I have it), which to me leads me to blelieve it wasn't coded to know about the L7 external amp / speakers, etc. I also noticed that it only allows for line-in, as I dial through the other options (FM, AM, CD, etc...) and it doesn't "engage", like it cannot be selected.
I have never programmed my car, but I am up for the challenge. My question is:
1) Does this sound like it is the issue I have? Needs re-programmed to know about my L7 system?
2) Is it same to assume the new unit will work? I spent quite a bit and the seller has been cool, but I don't want to go too long if this is a bad assumption
3) To program, what will I need? I know a cable and NCS Expert...
4) And of course, any guidance on how to enable the proper settings would be AWESOME
5) Or, do I take it to a shop and pay $$$$ to get it working...or maybe not?
I really just want to know if this unit will work, if coding is the right next steps, and lastly how to get'r done.
Thanks E60'ers!
DaveR
Note - I noticed in another post there are multiple stereo options, and coding solve their issue...but I need some guidance - PLEASE
Thanks E60'ers!
DaveR
My Ride: 2007 550i
Try the following link, NCS Expert do BMW E60 CCC Coding/Programming | OBDII365.com Official Blog.
Does anyone know if the lack of sound all around is related to the missing Logic 7 programming?
Thanks,
Dave
You gotta code it. I've never done it myself but I heard you have to code in your VIN.
My Ride: 2007 550i
Thanks all. Sounds like coding will do the trick. If there are any NCS experts that can point me to the best download, and best information, I would be greatful.
Thanks again all - appreciate the quick responses!
DaveR
DaveR
My Ride: 2007 550i
That person would probably be @seanjordan20 .
Thanks,
DaveR
DLH525i2007 (11-20-2021)
There's also services where they can do the coding for you remotely if you get to the point where you feel like your head is going to explode.
My Ride: 2007 550i
Thanks - Good to know.
My hope is I can just record the VIN in the CCC for the modules that were swapped and it will work. That is probably my real question at this point. I didn't want to make any other coding changes - hoping it is this simple and would like to know which SW is best for this...
Thanks,
Dave
Thanks,
Dave
