need a new transmission! smh. fml.
My Ride: A mean 5 series sitting nice... Lol
Sooo, I have an 06 525xi with 78,000 miles and I received the TRANSMISSION MALFUNCTION message. I turned the car off n back on and it went away. It happened a few times but I couldn't get it checked because my mechanic was out of town. Then it popped up again but this time wouldn't go away. My mechanic gets back and takes a look at it and I need a new tranny. Any 1 know how much this should cost to fix or what the going rate for a rebuilt vs used tranny is? Anyone know a good place to find one? My mechanic knows but I like to do my research as well. Thanks for the help!
What were the error codes that lead your mechanic to declare the trans is dead?
New trans will likely cost around $7K including labor cost.
Remanufactured/used trans will likely cost around $4K.
IMHO, your trans can be repaired by replacing the solenoids alone or the entire mechatronics unit; less than $1500. First understand (not just someone saying "you need new trans") what exactly is wrong with the trans.
i have almost same problem.. 2006 n52 530i with 63kmiles
i change the fluid and still have like a "metal bang right under the center console.under the car" when i press hard the gas pedal .esspecialy from 5-6. gears
lets say i cruise in D at 80mph at 2800rpm(6th gear)..then..if i have to pass fast i punch the gas pedal..and the car goes in 5th gear ,raise to lets say 6krpm..and then in 1 second change to 6th gear and goes back in 5th(this happen also on DS and on M5-M6)..((
WHAT THIS CAN BE???
i think the only answer for our problems only DEALER CAN answer..witch will cost us $$$
MY DEALER say he couldnt find any falt codes ???i thought if a error disappear by herself it still can be read in the history of the ECU !!
SO HE told me that even if they drove the care ( a technician took the car home for 2 days) he CANT REPRODUCE the same "bang" that i had
i am so sad that such a nice car as ours give us so "x-files" wondering
good luck..
WHAT THIS CAN BE???
good luck..
My Ride: 530i
Engine: M54
OP, please post the specific fault codes that were stored.
Sounds to me like you're getting the typical 'shotgun-blast' approach to fixing your car, which takes minimal effort from them and maximum money from you.
WHAT THIS CAN BE???
good luck..
WHAT THIS CAN BE???
good luck..
Generally speaking, your DEALER doesn't know SQUAT about the transmission and won't attempt a repair. The DEALER only wants to REPLACE it with a rebuilt unit.
I am not saying you necessarily have the knowledge or skill to do this yourself, but there are repair shops that do. $1500 or $7000. Your choice.
so in another words i should demand them to replace the solenoids or the megatronics ( if they wore able to read the codes it will be simple..replace one or another but if no codes i should go with the solenoids??)?
thx u
p.s
monday i am going to drive it the way i drive it..with the technician in the passenger seat..
and we see from there
thx u
p.s
He said the codes that showed was for gear ratio monitoring 4/5.
WHAT THIS CAN BE???
good luck..
WHAT THIS CAN BE???
good luck..
thx u
p.s
and we see from there![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
thx u
p.s
Dealers provide component replacement. Some are known for replacing multiple components until they stumble upon a solution.
My Ride: 530i
Engine: M54
I have not heard of BMW dealers doing mechatronic replacements or individual solenoid replacements within the mechatronics unit. Nor do they rebuild alternators, AC compressors or starters.
Dealers provide component replacement. Some are known for replacing multiple components until they stumble upon a solution.![Big Grin](https://5series.net/forums/images/smilies/imported/biggrin.gif)
