Need Help with wheel specs...
I am looking at fitting my e60 with a set of 19" wheels, here are the specs...
FR: 8x19" ET 37
BK: 9x19" ET 39
I know the recommended offsets for e60 are 15-20FR and 20BK so if I put 20mm spacers front and rear I should be OK correct?
Also I imagine I would need longer bolts? Does anyone have any info/advice for me regarding setting this up?
Thanks for your help
One more thing, these wheels are from an e92...will there be any issues with the center bore?
Thanks.
FR: 8x19" ET 37
BK: 9x19" ET 39
Thanks.
My Ride: 2007 530d M Sport Automatic, Le Mans Edition.Le Mans Blue Individual Paint Special, Syrah Blue Individual Leather, Piano Black Individual Interior Trim, Front seat heating,M Double Spoke 172 19
Should be ok ,PCD and centre bore are the same on OEM rims and you will need 20mm longer bolts.
madein
06-06-2015 11:48 AM
Virak1985
06-02-2015 11:16 PM
