Need help with wheel spacers sizes
So i need some help. I have a 2009 550i that I will be putting E60 M5 style 166 wheels on. Tire size that i will be using will be 245/35/19 in the front and i have a choice of 275/30/19 or 285/35/19 in the rears. Which one of the rear sizes will work with no rubbing and look better? Also which size spacers do i need to use in the rears the get the best look and stance for the car? Also do i need to use spacers in the front? PLEASE HELP all info is appreciated Thanks
My Ride: 2008 528i Sapphire Black | Sport | Premium | STEPTRONIC | Xenon
my choice was 285/30/19 in the rear on my 166's with no issues and a 12.5mm spacer in the rear.
there is a set of 166s with offsets meant for an M6 which has a lower offset. if you have that set you will not need spacers in the rear. if you have the M5 set, the rear offsets should be ET28 and a 12mm spacer would bring the wheels flush. if interested we do have 12mm spacers good in stock
Also if i have to use the 12mm spacer do you know which tire size would be better for the rear 275/30/19 or 285/35/19 ? Also the car is not lowered and i dont plan on lower it because i want the stock ride. I just want to get an idea whats the best set for these wheels to make them look good.
Thanks for all your help.
