Need Help Please
My Ride: '04 545i SMG, silver grey, grey Dakota leather, dark poplar, 124's, Nav, Logic 7, PDC, CWP, xenon adaptive lights, comfort seats, electric rear sunshade, hardwired V1, Bluetooth, Aux input, Progman 25, poplar wood trim front lower dash and rear cente
Hi everyone,
Need some help please. Periodically when I re-start my 545 after the car has only been shut off for a short while (like when I'm running some quick errands, etc...) the car will initially start up just fine, but won't idle properly. It stutters a few seconds then just dies. :'( I turn the ignition all the way off, and re-start again and everything is just fine. This has been happening more often recently and I'm wondering if this is happening to anyone else? What do you think the problem might be? Faulty O2 sensor? Any other ideas?
Thanks
Thanks
Not 100% sure if it's the same, but my E39 540 had that problem, as did many, apparently, and the culprit was typically either the camshaft position sensor (CPS) or the mass air flow meter (MAF).
In any case, it's clearly a warranty issue, and let's hope it doesn't become common for our 545s.
Thanks for the comments. I have a service appointment tomorrow so hopefully it will be easily resolved. Of course this usually only happens when I have a passenger in the car to give me grief about how my new, expensive BMW can't idle properly... ugh!!!
