need help with my bmw 530i 2004 transmission
My Ride: 2004 530i
Hello guys
i bought my car since 1 month back which was 240000km since i bought it every thing was going fine till today when driving on 100 or 120 and slow down to 40 or 50 and then push the pedal again it does not respond for 1or 2 secand then hearing jerk in tramission after running again there no any fault massage in screen or computer checking also when moving normaly the gear shfitting normaly.
Any ideas here regarding this?
My Ride: e60 530i
Transmission is most likely going out. Its not at the breaking stage yet but it is getting there. I would start looking into getting one from a salvage or junk yard. I replaced mine at it cost almost 7K from the dealer
My Ride: 2004 530i
My Ride: BMW 550I BLK
Engine: N62
I had a 04 530i also and my tranny started doing the same thing at just over 100k and got worse and worse the dealership kept saying I needed a new one. I asked for a fluid change and they said the fluid was life time the problem got worse. Well I got turned on to the indy shops and they said a whole different thing. They said it could be the megatronics unit or megatronics sleeve needed changing. So it wasn't the unit so they changed the sleeve and the problem was still there And by then the car was going into limp mode real bad I had to stop the car and turn it off and back on for it to reset. I had no power coming off stop signs or lights. Went back to the indy shop and the opened the tranny to find my gears were grinding down and chipping off. They cleaned it out and gave me new fluid but the damage was done. However I learned how to drive the car on that bad tranny all the way to 276k miles. But thanks to this site and bimmer fest I am well informed and i have a 550i now and it gets the royal treatment
My Ride: e60 530i
Whole tranny. They opened it up and everything was done the gears were burned up they said the oil was toasted so they had to put in a new tranny luckily I had warranty still so it was covered with a $100 deductible. I would advise you to get the warranty if you can
