Need help ignition wont turn on after jump starting the car
Check the fuses in the power distribution box. It's the fuse box above where the battery is located. I'm certain maybe a blown fuse (ignition fuse) or a bad relay or whatever is causing this. Good luck
edit: There's also a fuse box located behind the glove compartment. I'd take a look there also
![](https://5series.net/forums/public/style_emoticons/default/thumbsup.gif)
Awest91
09-17-2022 11:05 PM
