Yesterday, I went out to eat with my girlfriend and when we got back in the car and I tried to turn on the car and got greeted with a trans error, oil pressure low warning and engine fault. The engine would stop working after about 2 seconds, after waiting for sometime and trying a couple of more times it finally started and I drove off, but heading back the engine turned off again mid drive. I made it back home checked the oil level and it was normal. Saw some yellow gunk but I figure it was just condensation.
I had a mishap with the trans a week back where I threw it in reverse and it would just rev RPM's but not drive backwards.
Gonna take it to a mechanic/electrician after I get paid and i just want to know how much is the damage 😃
I only see an issue with your oxygen sensor. You should have your battery and alternator tested also ensure you're not leaking transmission fluid. Seems to be the cause of an old battery or failing alternator
i only see an issue with your oxygen sensor. You should have your battery and alternator tested also ensure you're not leaking transmission fluid. Seems to be the cause of an old battery or failing alternator
