need help 528i 2008 bi xenon retrofitting
Old 06-07-2009, 09:51 PM
s012205's Avatar
Hello
I have 528i 2008 which came with a standard hallogen lights. I retrofit it with bi xenon headlight. I just have one problem with the highbeam as in this model 2008 the outer light work both as low and high beams using the shutter. The bulb (35 watt) inside the inner light is used for the angel eye. So I connected the wire that goes to the high beam in the standard hallogen light directly to the shutter. It works the shutter could open the high beam from the xenon bulb but it gave me an error that the high beam light is malfunction. So I attached Capacitor (4700uf 35 v) to get ride from the message. Now the error message is not there when I siwth the car on but when I push the stack backward to activate the high beam the error message apear again and stay there until I swith the car off. When I push the stack toward me there is no error message. Also while I'm driving the high beam comes on for a second by itself whithout pushing anything. Is there any solution for it??
The xenon light and angel ayes works great without any error message.
Black5123
10-14-2023 01:46 PM
Beemer
33
01-14-2019 05:13 AM
Skavilla
04-21-2015 03:43 AM
CertifiedOfficial
04-13-2015 08:24 AM
jl21
03-29-2015 09:53 PM
Quick Reply: need help 528i 2008 bi xenon retrofitting
