Need help
Old Aug 27, 2018 | 11:55 AM
Bimmerlat's Avatar
My Ride: E60 545i stock
Originally Posted by FormerE30Owner
Depending on how serious the problem is and how concerned you are about a small oil burning problem and local regulations, I wouldn't do anything until you see smoke all the time. That could be a while before it gets much worse, if its really only the stem seal problem.
thanks for that it's not bad I did a lot of driving today only notice after an hour I bit coming out when idle in traffic. A few times before at home at idle after a while I reved up quite a bit come out. So the idea is not to give it the beans at idle.
Old Dec 1, 2022 | 07:15 AM
habbyguy's Avatar
My Ride: 2006 530xi (Touring)
I think the clue that's significant is that it seems to run fine after it's warmed up. The scenario that pops to mind is the difference between the open loop condition (from a cold start, until your upstream (pre-cat) O2 sensor is fully warmed up) and closed loop (when your engine management software is using readings from your O2 sensor to set the fuel injection parameters).
If there's a problem with the fuel pressure (for example) the pre-set "program" for start-up operation might result in too-lean or too-rich operation. Then, when your O2 sensor reaches proper operating temperature, the ECM could adjust accordingly.
But there are other things that can cause misfires in the cold-start scenario - check your air filter, vacuum leaks, etc.
Old Dec 2, 2022 | 02:05 AM
gman6262's Avatar
My Ride: 2010 535xiT Touring, N54, Individual Audio
Model Year: 2010
Engine: N54 3.0L Twin Turbo
Check this out:
Pavlokaz1974
Jul 21, 2011 04:01 AM
Pavlokaz1974
Jul 20, 2011 10:05 AM
skelevirus
Lounge
35
Jan 25, 2010 04:59 PM
Sajjid
Feb 1, 2008 06:14 AM
///M Lifestyle
Aug 26, 2007 02:42 PM
