Need help
Can anyone give me some advise it's a blue smoke issue
the drives fine no smoke nothing when driving. Stationary I can sometimes see a light blue smoke only on stationary.pulling away no smoke nonpuff of smoke or anything Left the car to idle for ten mins at home looking at pipes where I can see smoke conning out but not a lot.,but when I rev the engine large amount puffs out. work done oil change crank case vent valve oil separator hoses seems like this hasn't worked , any thoughts from anyone thanks |
How many miles do you have on the car? What made you change the oil. Was the oil level low? Are you getting a rough idle or hearing rattling noise?
(Post 1596564)
I don't know what oil was being used before I do know mobile 1 was used last service about 500 miles ago,at one stage oil wad very low as there is no indicator to show. No rough idle or rattling |
103k on the clock
check a spark plug for oil.
The most common reason is leaking past engine seals and into the cylinders where it then mixes and burns with the fuel. Do you have an oil leak dripping on the exhaust? This can also cause what may look like blue smoke. |
bad valve stem seals. Common problem on the v8.
Originally Posted by newspeed
(Post 1596599)
so question is because of cost around £2000 get this done or new recon engine? Similar figure dilema.... |
Originally Posted by Bimmerlat
(Post 1596603)
done a research on this and the signs are there mines not bad at mo but will get worse over time
If your engine is in good condition I would do the repair. You will never know the history of the recon engines or what problems they might have. Always best to keep the original engine if possible.
(Post 1596604)
I'm going to answer my own question and get the stem seals changed this way I can get head gasket and chain guide done amongst other things with in reason, re con engine not always the best thing to do ??
