Need help
My Ride: E60 545i stock
Can anyone give me some advise it's a blue smoke issue
the drives fine no smoke nothing when driving. Stationary I can sometimes see a light blue
smoke only on stationary.pulling away no smoke nonpuff of smoke or anything
Left the car to idle for ten mins at home looking at pipes where I can see smoke conning out but
not a lot.,but when I rev the engine large amount puffs out.
work done
oil change
crank case vent valve
oil separator hoses
seems like this hasn't worked ,
any thoughts from anyone
thanks
work done
oil change
oil separator hoses
thanks
Engine: 3.0 B58; 3.0 M54
How many miles do you have on the car? What made you change the oil. Was the oil level low? Are you getting a rough idle or hearing rattling noise?
I don't know what oil was being used before I do know mobile 1 was used last service about 500
miles ago,at one stage oil wad very low as there is no indicator to show. No rough idle or rattling
check a spark plug for oil.
The most common reason is leaking past engine seals and into the cylinders where it then mixes and burns with the fuel.
Do you have an oil leak dripping on the exhaust? This can also cause what may look like blue smoke.
I'm going to answer my own question and get the stem seals changed this way I can get head gasket and chain guide done amongst other things with in reason, re con engine not always the best thing to do ??
If your engine is in good condition I would do the repair. You will never know the history of the recon engines or what problems they might have. Always best to keep the original engine if possible.
My Ride: 2005 545i, premium package, 6sp manual, cold package, navigation package.
Model Year: 2005
Engine: N62
