Need to get inside trunk from rear seat, need help
If you had no metal wall how did that speaker fit inside there? I haven't removed my backplate yet. There are several small holes on backplate perimeter and I poked with a screwdriver and heard metal so I presume there is a metal wall there.
I cut my ski pass on my own too... I left the seat in the car when I did it, though. I measured both sides to make sure I knew where I wanted everything and then drilled a couple holes in either corner and then used a recip saw to cut the square ski pass. This, of course, is with the pretty plastic piece out of the car. I then cut a similar hole in the black plastic piece. Lastly, I covered the entire black plastic piece with black speaker carpet basically covering my newly cut ski pass hole right back up. The idea is that the ski pass is there allowing bass into the car but, since I drive with that back arm wrest down, I can't actually see into the trunk because that carpet is there as something more attractive to look at than a hole into the trunk. Also, I didn't want warm air from the trunk seeping into the car in the summer next to the kids in the back seat. I'll grab a couple pics tonight and upload.
