Need ac help!
Old 09-25-2024, 08:15 PM
Prater346's Avatar
My Ride: 07 BMW 530xi
Default Need ac help
Look at your whole list and post them. There's things that affect the a/c that doesn't fall under the IHKA. This is why I keep asking for all the codes to make sure you're troubleshooting correctly.
sorry it took so long to return. Been out of town for work and working daylight to dark.
the only errors I’m having are
9c79 and 9c7a both water valves, in which I have replaced and the error code is still there after clearing.
2f0d radiator blind activation (I don’t believe mine has active radiator blinds)
a36b Bluetooth fault (MULF ) Not sure why that one is throwing. I did replace, program, and code replacement CCC unit but Bluetooth works fine. Minus the microphone and voice control but I was told a code was needed from BMW to reactivate. That is all the codes listed.
im leaning towards a bad replacement valve but all values in analog diag. Are exactly the same as the old one.
Old 09-26-2024, 11:16 AM
Allen's Avatar
My Ride: 535i 6-speed
Have you tried something as simple as adding refrigerant? It's $35 at Walmart. Easy thing to try.
Old Today, 07:35 AM
Prater346's Avatar
I’ve tried but something is keeping the compressor valve from opening. The system will not take refrigerant. The system vacuumed down fine and held with no problems.
y0itzflip
05-11-2019 06:35 PM
Billy Mo
05-24-2018 08:23 PM
Darkchild
07-15-2012 08:26 PM
tuffluck
07-31-2011 05:23 PM
bighersh
06-29-2011 03:04 PM
Quick Reply: Need ac help!
