Nav Failure
I made a backup using Nero. It worked fine in my car and also in a friend's Mini. My Nav also got hung up last weekend. Kept asking for me to insert the Nav disc and I kept ejecting and re-inserting (joke concering wife loving that left out due to possibility of offending any sensibilities) but nothing worked. I finally pressed both cd and dvd eject buttons and the i-Drive knob simulaneously. Although I'm not exactly sure if that is the infamous i-Drive reboot combination, that worked like a charm.
Sam
Sam
Originally Posted by sj3' date='Feb 26 2005, 06:46 PM
I finally pressed both cd and dvd eject buttons and the i-Drive knob simulaneously.? Although I'm not exactly sure if that is the infamous i-Drive reboot combination, that worked like a charm.
Sam
Sam
[snapback]94799[/snapback]
CD Mute and iDrive!!!!
Guest
Posts: n/a
Originally Posted by skipper' date='Feb 26 2005, 01:05 PM
About 4 days ago my Navigation system failed. It now shows "please insert navigation DVD" even though it is in there. When you hit the eject button it does not come out either. I remember someone else had this problem a while ago. Is there a way to force it to eject, such as a computer CD drive has that little hole in the front that you stick a paperclip into? Car is going in for service on Wed.
[snapback]94669[/snapback]
It was me who had this problem about 6 weeks ago. I was on the SW version, probably 12.x that the car was delivered with.
You can Eject the disk if you do it before you start the car after it's gone fully to sleep(over night). Once I-drive has booted you won't get the disk out.
The service tech noted he did a "battery reset"( I assume he discontected the battery for a period) and he upgraded the software. The notes don't specify which remedy fixed the problem. I will try the battery reset if it happens again to me before taking it in.
I also had along list of other software related items too. i.e. DME recall, bluetooh retrofit etc. so I don't know if the software was required to fix the NAV problem.
Oops! I forgot to login...
[snapback]94947[/snapback]
Guest
Posts: n/a
I have Business NAV, and i get the exact same problem, usually followed by the whole Idrive etc, rebooting itself several times. Sometimes fixing itself, sometimes not.
This is with original Nav disc, i find it funny when BMW say copies can damage the idrive! What BULL****! More like copies can damage BMW pockets!
I had the software upgraded (dont know the version) and things were fine for a while, but now its happened again a copule of times.
BTW I dont have seperate buttons for DVD and cd in BUS NAV, only 21 slot. How do i reboot for this setup?
My Ride: '05 545 Sport Week 9
Originally Posted by EBMCS03' date='Feb 26 2005, 09:49 PM
[quote name='sj3' date='Feb 26 2005, 06:46 PM']I finally pressed both cd and dvd eject buttons and the i-Drive knob simulaneously.? Although I'm not exactly sure if that is the infamous i-Drive reboot combination, that worked like a charm.
Sam
Sam
[snapback]94820[/snapback]
[/quote]Can you explain the reboot combination for NAV cars? press DVD and CD Eject buttons? at same time as pressing radio mute button? Please clarify. Thanks much
Originally Posted by TitaniumGray5' date='Feb 27 2005, 05:31 PM
Can you explain the reboot combination for NAV cars?? press DVD and CD Eject buttons?? at same time as pressing radio mute button?? Please clarify.? Thanks much
[snapback]95089[/snapback]
Originally Posted by EBMCS03' date='Feb 27 2005, 06:53 PM
[quote name='TitaniumGray5' date='Feb 27 2005, 05:31 PM']
[snapback]95099[/snapback]
[/quote]Thanks, I'll file that one away in my noggin for the inevitable day.
jcolley
08-01-2016 06:48 AM
Bank$hot530
09-16-2015 01:28 PM
