N62 Engine Covers - To paint or not to paint?
rock it with the cover off. i yanked out my hood insulation as well as the cover (supposedly a sound deadener as well as for looks). looks okay but not for everyone i guess.
My Ride: 2004 Dinan 545i, Titanium Metallic Silver, 2007 Dinan M5, 6sp, Silver Gray Metallic
My Ride: 2005 545
My Ride: 2005 545
My Ride: 545i
Engine: N62
To all who posted, the pics look great!!! ![Twoup](https://5series.net/forums/images/smilies/imported/twoup.gif)
What kind of paint was used and what prep do you have to do before painting. My engine cover is dirty!!! I tried cleaning when I replaced the sparkplugs, but they did not come out as clean as I hoped. Did you remove the cover to paint?
Thanks!
Thanks!
Thanks!
Thanks!
My Ride: 04' 545, 6 Spd Manual, Blk Lthr, Sport Pkg, Sport Sts, Logic 7, Cold Wthr Pkg, Full L.E.D. Interior, Red Eng. Cvr, Mtech Front Bmpr, M5 Spoiler, Matte Blk Grill, Red Caps, Slttd & Drlld Rotors, 20
I used VHT engine enamel. Primed it first with a flat grey. I washed with dawn before I painted it, lol. Like Vapiano any high temp spray paint should work.
Go back and read the second post, there are some tips in there that you may want to consider. Otherwise, you can simply go to your local store and purchase a cheap rattle can of paint and then deal with the fisheyes looking up at you when you open your hood and there is a good chance of the paint peeling off in spots or completely due to an adhesion problem. The material used in the cover is PP and when you paint it there are very clear steps needed to ensure adhesion. Again, you can go take a can of rustolium, but if you are serious about it and want it done correctly then you need to do some special prepping things first.
My Ride: 2005 545 6MT
Mine has been painted for almost three years now and only had to touch it up once (cracked knee on tool box reaction was to kick something). All I did was clean it with purple power, let it dry completely, mask, prime, and paint. I used high heat engine primer/paint from autozone. Did a couple of coats of primer and 4 or 5 coats of semi gloss engine paint. If it were something going to a show, I would have sanded, primed, paint, clear, and wet sand/buff. For a daily driver and something I see not so often, I like the way it looks now.
My Ride: 2005 E60 545i Manual, Sport, L7
Model Year: 2005
Will the 3M de-noc vinyl stay on with the heat? Thinking to put it on engine cover using the primer 94,
Have anyone done it?
