N62 Check engine light 3 codes
Old Oct 2, 2019 | 07:12 AM
loco 1's Avatar
My Ride: 2007 bmw 550I /N62 Engine
Model Year: 550 I 2007 Sedan
Engine: N62
Angry N62 Check engine light 3 codes
Hello is me Loco 1 and my 550I n62 engine I have two engine trouble code P011 and P0016, after checking out the engine,I know the engine needs valve seals and timing
Good morning, I am new to the 5 series community and this is my story on my N62 Engine.
I remove the engine to replace the valve seals and replace timing chain tensioner, guides, and all gasket. I rent a tool to do the timing chain and line up the cams to set the timing,I repeat the proses several time. I'm 100% sure that the time is ok. install engine start engine,sound good runs real good no leak. but a lot of trouble codes I do not have a BMW scanner codes I have an OBD codes CODE P011, P014, P017, I clear all code but the come bag? I check all connections, I check the cams sensors whit an om meter, reding was ok, check Vanus connection ok remove Vanus and bench tes all good oil cleand. any suggestions?????
P011 Camshaft timing over advanced or system performance bank A
P014 Camshaft timing over advanced or system performance bank B
P017 Camshaft position camshaft correlation
Old Oct 3, 2019 | 07:03 AM
FormerE30Owner's Avatar
My Ride: 2005 545i, premium package, 6sp manual, cold package, navigation package.
Model Year: 2005
Engine: N62
Unless you get a BMW scanner, you cannot use really know what those codes mean.
Old Oct 11, 2019 | 08:59 AM
loco 1's Avatar
Engine: N62
Good morning, After rechecking all my connections and setting on my N62 engine, I remove the valve cover for Bank1 and double-check the timing on both cams I did some minor adjust mean on the two cams, The engine is running real good at idle and while driving. but know I have 3 check engine light codes.
2A8A VANOS INTAKE
2A8C VANOS OUTLESD
2A90 OUTLET CAMSFAT GOG OFFSET
I take the vanos out tested in the bench, tes was good for bak 1 and 2, I put the one on bank 1 on the Bank 2, no changes. I was looking at the forum and some said the I have to Re-enable Ram Back-Up, some said to put Sea Foam and drive for a while.
Question: isthe is another way of Re-enable Ram Back-Up, whit out taking the car to the BMW dealer, My scanner is a ZURICH 13and I don't think the I could use. Please help any suggestion will be appreciated.. Thank you...... Loco 1
Old Oct 17, 2019 | 05:05 PM
loco 1's Avatar
Engine: N62
Well, it looks like nobody wants to help. I'm down to one check engine light code 2A8F or P0016.
I have check all vanos, my timing is good I have checked several times, time is good I purchase the special tool to set the timing. The codes said intake camshaft 2, cog offset of crankshaft. I donth have any Idea where to star.......anybody have any suggestions.
Old Oct 17, 2019 | 06:23 PM
seanjordan20's Avatar
Engine: 3.0 B58; 3.0 M54
Remove the solenoids and blow air in it to clean them then clear the adaptions. Use DIS/GT1 for the RAM
Old Oct 6, 2021 | 08:41 PM
Jaybando550's Avatar
Probation Members
My Ride: Bmw 2008 550i
If you don’t mind helping me out my car literally has similar issues
sxybeemr
Jun 20, 2023 10:13 AM
e6t.lab.rat
DIY: Do It Yourself
74
May 14, 2021 08:00 PM
subieworx
Sep 21, 2015 01:19 PM
stewart@pt.lu
Feb 26, 2013 06:15 AM
jp1580
Feb 11, 2011 04:46 AM
