N54 recall: is there a way to determine if my 535i is included?
My Ride: 2008 535i Sport / Premium / Manual Trans
My car is at the dealer for a check-up.
I asked if my car was included in the N54 fuel pump recall and the service advisor said "there are no recalls currently affecting your car".
I want to make sure I get the new pump if I need it. Is there any way to determine if my car is supposed to get the new pump?
Did they tell you that it did need a software reprogram? I have been reading others experience and it appears that most if not all of the 535's from 2008 are at least getting the software update and if there is a failure after the update then HPFP, Injectors etc will be replaced.
My Ride: 2008 Deep Sea Blue 535xiT Sports Wagon
Cold Weather/Premium Packages
iPod
Nav
No software update performed. I believe it was done last year when I had some fuel injectors replaced.
I thought that was the HPFP but apparently not. No issues since.
My Ride: 535XIT Space Gray, Cream Beige LeatherCold Weather, Premium, Auto, Rear Side Window Shapes, Heated Rear Seats, Park Distance, Navigation, Satellite Radio
Model Year: 08
They reprogrammed my 535XIT in November and the fuel pump failed Feb 2011. The car has 30,000 on it and I have used only Shell & BP gas. The service manger also said the the waste gates of the turbo's were not right and being adjusted.
Model Year: 08
Has anyone had the new replacement fuel pump fail?
Do you think that BMW has finally found a fix?
Model Year: 08
Wow, sorry to hear that... :thumbsdown:
