Mysterious burnt oil smell
My Ride: 2006 525i
Model Year: 206
I am driving an 06 525i with N52B25 engine and has been struggling with this burnt oil smell in the cabin for the past 18 months.
The car used to have severe oil leak when I bought 2 years ago and I have done all the major maintenance/replacement to fix the oil leak including
- New valve cover gasket
- New oil pan gasket
- oil cooler gasket
- CCV and all hoses attached to it
- vanos solenoid and O-ring
- Valve stem seal
and alot other gaskets I could see on realoem.
The oil leak reduced significantly but I do have oil leak somewhere (couldnt see by the eyes/ engine pretty dry now). Especially whenever I go hard on the accelerator, there immediately a burnt oil smell in the cabin and if I continued to go hard then the oil level on idrive shows a small reduction.
Any advise where to tackle this since I almost give up on this oil leak thing. Thanks
- oil cooler gasket
- Valve stem seal
My Ride: 530xi 6sp
from the recent research i did, could be broken alu vc bolts or oil filter housing gasket (if you have yet to do that). trying to figure out my nasty cabin smell as well.
My Ride: 2006 525i
Model Year: 206
I replaced the oil filter housing gasket already . Then it me check on the valve cover bolt. These are such a PITA
My Ride: 530i
Engine: M54
- oil cooler gasket
- Valve stem seal
- oil cooler gasket
- Valve stem seal
My Ride: 2006 525i
Model Year: 206
Do you have the part number for main seals?
