MY Xenon's do not mover "side to side" ...
My Ride: 535d Titanium Silver, Black Nasca Leather, Servotronic Steering, , De-Chrome, Bi-Xenons including Headlight Washer Jets, adaptive headlights, Advanced A/C, Auto Dim Interior & Exterior Mirrors, Electric Folding Mirrors, Front Centre Sliding Armrest, extended lights package
is there a mix up here between active lights which do exactly as other members have said i.e. move in the auto position and non active lights which when you switch them on at first self adjust a little
do you have active lights that steer around corners?
My Ride: 2004 e60 M5 Replica
Titanium Silver
Premium Package
Premium Sound Package
Adaptive Xenon's
Apple iPhone cell interactive pared with iDrive Bluetooth setting
19 inch BMW OEM 166M rims,
Michelin tires
Sprint Booster - V2
Fidelity / BMW Extended Warranty 7 year / 100,000 miles
Originally Posted by the-man-himself' date='Dec 29 2004, 06:44 AM
is there a mix up here between active lights which do exactly as other members have said i.e. move in the auto position and? non active lights which when you switch them on at first self adjust a little
[snapback]73323[/snapback]
"the-man-himself":
No, that is what I was trying to say, (thanks), My Xenon's does not turn "side-to-side" for a couple of seconds anymore when I first cut them on, indicating their (working), active.
I did not notice them turning, when I turn my steering wheel, either.
That led me to think there is a problem with my active steering headlights, that needs BMW certified Mechanics/tech's attention to get it corrected properly.
What do you think?
Thanks,
Raymond Presley
IF you have active steering lights then they will only turn under the following conditions
lights selected to auto and if moving will turn both ways but if stopped they will only turn to the passanger's side to avoid blinding on coming traffic
otherwise you will have to visit the dealer as i also understand it the little green light beside the auto position will blink on and off to indicat a faul with active steering lights normally it should be on steady hope this helps
ps forgot to also say if selected reverse the active lights will not work at all
Titanium Silver
Premium Package
Adaptive Xenon's
Michelin tires
Sprint Booster - V2
otherwise you will have to visit the dealer as i also understand it the little green light beside the auto position will blink on and off to indicat a faul with active steering lights? normally it should be on steady hope this helps
[snapback]73381[/snapback]
THANKS! You info. is a great help, (I feel the same way you do about my active headlights, and I never knew that about the little green light, blinking on & off to incicate a fault with them, interesting, thanks again)
have a good day!
Sincerely,
Raymond Presley
