my trunk won't open
My Ride: 2004 BMW 545i
My trunk won't open if I push the trunk button inside the car on the drivers side. It also won't open if I unlock the car and use the button on the trunk, or put the key in and turn.
THE ONLY WAY I can open the trunk is to use the button on the key fob.
I couldn't find anything in the manual about a switch for valet that could possibly deactivate the trunk.
Any idea what it could be?
Engine: N54
Hmm. I'm sure you believe and experience what you are describing but I am going to go with what you are saying is not exactly the full/correct info. I can not think of any reasonable way that your trunk will open remotely but not with the key unless there is more information to be shared.
i'll check the fuses, but the trunk opens electronically from the keyfob, so I don't think it's the current being interrupted.
does this car have a valet switch? it's the only thing i can think of to cause the trunk not to open with the car buttons.
I also found this post on another forum that describes my exact problem.
http://forums.bimmerforums.com/forum....php?t=1802429
My Ride: 2012 535i X-driveSpace Grey/Black Dakota, Fineline Anthracite Trim; Executive Package (Rear View, Lumbar, Nav, Voice, SIRIUS, HiFi Pro) Technology Package (Hi Beam Assist, Lane Departure, Blind Spot Detection, Surround View) BMW Apps (Apps, Smart Pho
Model Year: 2012
E60s don't have a valet switch. The only way to keep a valet out of the trunk is to lock the trunk with the metal key in the remote. I can't imagine what circumstances would negate the metal key from opening the trunk.
GL
GL
Engine: N54
http://forums.bimmer...d.php?t=1802429
Thank you everyone! I wish BMW would mention this feature somewhere in the owner's manual.
Model Year: 2012
THANK YOU! OKAY so I had no idea, but apparently you can just turn the key a certain way and it locks the trunk. It prevents the trunk from being opened by any switch in the car or on the trunk itself until you unlike it with the metal key. I guess I didn't turn it the right way or something, but I just went to the car and started playing with it and the trunk opens now.
My Comfort Access remote puts them down but not up (without some coding).
skrelnik
09-18-2015 07:24 AM
Island Road
09-12-2015 06:47 AM
slow.motoren.werke
DIY: Do It Yourself
08-25-2015 03:46 PM
