5Series.net - Forums
-   -   is my idrive dead pleas help (https://5series.net/forums/e60-discussion-2/my-idrive-dead-pleas-help-134036/)
noberryafterdingl Jul 18, 2013 06:58 PM
i went to formation this mornin at 0430 plugged my phone into aux and was fine, had music, legal disclaimer etc..i then got back int the vehicle at 1200 it was 96 degrees out windows rolled up to my surprise the idrive did not come on.. insted u could see the backlight with a black black screen with very faint white lines..... still got all the chimes parking sensor still worked, no radio, no aux-in, no bluetooth, checked fuses in the trunk or boot radio amp, and video fuses were fine need to know if i can diagnose with inpa.... i can do simple coding with instructions
can someone tell me what are my options with replacement and coding/inpa
H F Jul 18, 2013 10:34 PM
check out this site BMW retrofits, coding and software updates - BimmerTech
noberryafterdingl Jul 19, 2013 04:23 AM
[QUOTE=H F;1513378]check out this site BMW retrofits, coding and software updates - BimmerTech[/QU
ive been looing at the combox but is that a plug n play or stand alone unit with out using the idrive computer
Gee_115 Jul 19, 2013 05:27 PM
What equipment do you have? If you have a MOST coding equipment (OPS, etc), you could try just recoding the entire CCC. I would try that route before spending money.
H F Jul 20, 2013 09:16 AM
[QUOTE=noberryafterdingl;1513394]
I don't really know bout the combo box .but if u purchase a new unit it should b plug and play and controlled thru the idrive knob. I like bimmer tech stuff cause its an Oem upgrade. I myself am probably goen that route I have an 05 idrive system and want a newer looking graphics and system.
I think Gee_115 is giving u good advice to recode first ,,makes dollars and sense. If it don't fix the problem then go for the upgrade.
dbond Jul 21, 2013 06:25 PM
You are likely S.O.L. CCCs are known to die from heat - breakdown of soldering within microchips. Your options are to get a used CCC or upgrade to CIC. The later will open a path to Combox.
