My E60 vibrates when it stops...
Could it be the control arm bushings are gone? Seems most likely to me, when they go they cause the wheel to move around excessively under braking which causes vibration
My Ride: 04' E46 325i Sold
05' E60 53oi Sold (tranny issues)
08' E92 328i coupe 6spd MT (Current ride)
+1 ^
if u have a shimmy when u start to brake.. then its ur CAB.. but if ur brake peddle gives u that pulse feeling then its ur brakes..
no...guys.. it's not with the brakes....
The car vibrates when it's completely stopped. Not in a move. Like at the red signal...
is 'idle' similar to 'vibration'? with a noise?
then yes.... lol I guess that's the one.
What's the solution...?
My Ride: I have a 2007 Black Sapphire BMW 530i with SMG. It has the auburn interior, has PDC, Sports Package, Premium Package, rear automatic sunshades with manual side sunshades, 35% black tint, Upgraded angeleyes from Angelibrights, and Logic 7 Sound System
could be loose motor mounts as well...but most likely rough idle is my guess! there are a few people on the forums with the same problems...look through the archives and you should be able to read up on it. Good luck
Engine: N54
Could be something as simple as the gas you are using as well.
Not sure about the "noise" you describe though.
Try running a few tanks of Shell premium through it ?? Skip the convenience stores and grocery store gas stations.
You an IU student? I'm a few hours north of you.
