My car just went BERSERKER!! Everything failed
it could be a bad voltage regulator which is only 125.00. This needs to be properly diagnosed. Might be the battery, generator, or voltage regulator. Or even a loose ground or corroded battery connections... anything that causes an under voltage situation.
Good luck!
Ken
Good luck!
Ken
My Ride: '05 545 Jet Black, Miro 111's, Painted Calipers, Slotted and Drilled Rotors, Ultimate Interior LED Kit, ACS Rear Spoilers (reps), HID 7k Fogs, Black Roundels and Badges, 20% Tint, Mtech V2 Angel Eyes, Ksport Coilovers, M5 Bumpers and Side Skits, ACS Front Lip (rep), and probably more on the way as you read this...
It was the alternator.
My Ride: Coming soon...
Bosch Alternator - 150 amp - price includes $73 refundable core charge.
Part # : AL0814X $ 329.95
www.bavauto.com
That one is in the range of the refurbished ones I've seen. If it isn't refurbished, and is the same part, that's an excellent price. I ended up getting one for $485 + install of $190. I found them at alternatorpros.com for $419 shipped next day, but the mechanic couldn't warranty it or the labor if anything went wrong, so I felt the extra $65 was worth it. If something went wrong with one from an outside source, even though it would be under warranty, I'd have to pay them to remove it, then deal with the warranty through another company, then get the new part and repay for an install.
Awest91
09-17-2022 11:05 PM
