my 2008 550i won't start until 10 minutes later.
Old 04-09-2014, 07:43 PM
Jim165's Avatar
You need to replace the IVM module. Common problem on 7 series, and some 5 series.
Amazon.com: BMW e53 e60 e63 e65 Integrated Supply Module 'IVM' electronic control unit e66: Automotive Amazon.com: BMW e53 e60 e63 e65 Integrated Supply Module 'IVM' electronic control unit e66: Automotive
Old 04-09-2014, 08:38 PM
abe76247's Avatar
My Ride: 2007 550i sport pkg 6MT
Isn't the starter relay a soldered in part of the IVM?
Old 04-11-2014, 06:57 AM
deen0o's Avatar
My Ride: 550i
Noboby ever had this problem before?
Old 04-11-2014, 08:17 AM
turboawd's Avatar
My Ride: 2006 BMW 550i
it could be anything. if it happens again, see if you can see if there is actually voltage going to the starter solenoid, so you can rule out a finicky starter at least.
Old 04-11-2014, 03:24 PM
Jim165's Avatar
Just posted the probable cause, man. It's probably your IVM module and it causes your symptoms with the no start issues. Do a search for IVM module and you'll see...
Old 04-11-2014, 07:40 PM
deen0o's Avatar
My Ride: 550i
I will try the voltage test first. I will definitely look into the IVM module. Thanks for the great advice everybody.
Old 04-11-2014, 07:52 PM
deen0o's Avatar
My Ride: 550i
After reading about the IVM problems...it really sounds like that's the culprit. Thanks my 5series buddies! I will replace It soon and cross my fingers.
Old 04-24-2014, 06:41 PM
deen0o's Avatar
My Ride: 550i
I just swapped out my IVM couple days ago. Let's see what happens.
Old 08-27-2014, 07:41 PM
Grod550i's Avatar
My Ride: 550i M Package
Was it the IVM ?
Old 08-28-2014, 08:16 AM
pradden's Avatar
My Ride: 02/2006 525i Titanium Silver Metallic Manual 6-Speed
Did replacing the IVM solve your starting issue?
I'm currently having the exact same problem with my 550i
Thanks!
Quick Reply: my 2008 550i won't start until 10 minutes later.
