Mtech Rear PDC (24mm) on 05 545i (17mm) - HELP!
My Ride: 05 545i 6MT
I have 05 545i w/ 17mm PDC holes trying to install Mtech Rear Rep w/ 24mm PDC holes.
My current 17mm PDC sensors are too small for the 24mm bracket/hole on the new bumper.
From what I have researched, I can buy this following part from BMW #7 but it's just a tiny rubber ring (saw it @ dealership)and it doesn't help.
http://www.realoem.com/bmw/showparts...54&hg=66&fg=05
Decoupling ring PDC torque converter 8 03/2007 66209142107 $1.05
Is there any kind of bracket from BMW OEM or anything I can buy to fit the 17mm on to the 24mm hole?
I need help from those who have done this before or probably know a good solution to my problem is greatly appreciated.
My Ride: 2009 535xiT Silver/Gray with Sport, Nav, Cold, Convenience, Logic7 and more.
http://www.realoem.c...154&hg=66&fg=05
Salaki, that PDC holder you are holding in your hand, does it have a double-sided tape (red) on it?
Is this how that holder is attached to the bumper cover?
I am trying to sort out similar problem for my E61 with PDC sensors : want to move sensors from stock bumper to M-Tech OEM bumper, but with no holes, so I can drill 18mm holes myself and _hopefully_ move my 17mm PDC holders with sensors over to M-TEch bumper
