MP3 Playback Problem "File / Track cannot be read"
Old Mar 19, 2009 | 02:40 PM
jeffjjoy's Avatar
I've recently burned an MP3 CD and if I put it in and it plays from the beginning it works fine. As soon as I try and go to a different song it will play for 3-4 seconds then it gives me the following error "File / Track cannot be read". I burned the MP3 CD using iTunes 8 and my system is the standard 10 speaker system in an 06 530i.
Any help is appreciated!
Jeff
Old Mar 19, 2009 | 02:45 PM
porsche911targa's Avatar
Jeff
Did you verify the disc when you made it? I mean, many burn programs can be set to"verify" the disc after you burn it? Once, I ran "verify" and it failed near the end. I decided that I did not want to waste more time re-burning it and when I played it, it worked fine at the beginning but had the same error you mentioned above.
Old Mar 19, 2009 | 05:15 PM
jeffjjoy's Avatar
I will try and verify this next one, otherwise I guess I have another coaster!
Old Mar 20, 2009 | 05:11 PM
neoe60's Avatar
Do a search, there's a thread with specific settings to use.
Some other things that might be a factor:
-laptop optical drives are inferior to desktop drives, so use a desktop burner if you have one
-burn at LOWEST speed allowable
-if you have old discs (2-3yrs) try getting a new pack of Sony, I was having trouble with some old Memorex that were read fine in a computer drive but was spotty in the car. I was gonna take it up w/the dealer but then decided to pick up a 50pk from Staples for $9 and haven't had any problems so far
Old Mar 22, 2009 | 04:45 PM
jeffjjoy's Avatar
Solved it... Once I switched the media it worked fine. I used iTunes 8.0 and burned it at max speed possible.
mainuser12
May 9, 2015 06:30 PM
DerekShiekhi
F10 M5 Discussion
Mar 20, 2015 11:11 AM
555
Feb 7, 2004 06:56 AM
paasan
Oct 12, 2003 11:14 AM
Jul 5, 2003 10:17 PM
