more creaking complaints
Rear seat/rear shelf area creaks like an old wooden boat when making left turns under certain circumstances when the car 'flexes' up incline/ decline then left turn. Driving me nuts Any one else with same problem (NOT from the door seals as that's been replaced / teflon taped, etc with no improvement). Is it reasonable if I ask the dealer to try replacing the shelf and/or seats? ongoing problem for 2 yrs now.
My car is at the dealer for the same exact issue. They said its the door seals first, now yesterday they called me and said its some other kind of seal they have special ordered. I will post again once I get my car back.
So far these things are getting replaced on a 04 530i with approx 30K miles:
1. Steering Wheel Column
2. New Brake Pads
3. Door Seals?
4. A Really Strange Noise from the passanger wheel well, techs at the dealership cannot figure out what it is
Things replaced just a month ago:
1. New Clutch
2. New Battery
3. Reprogram retrofit Bluetooth
2. New Brake Pads
3. Door Seals?
1. New Clutch
2. New Battery
My Ride: Bmw 530d 2004
Originally Posted by Markymark' post='583212' date='May 18 2008, 08:41 PM
Same problem here
You can't loose anything
My Ride: 2006 BMW 525i Jet Black. Pics will be posted soon!!
2. New Brake Pads
3. Door Seals?
1. New Clutch
2. New Battery
2. New Brake Pads
3. Door Seals?
1. New Clutch
2. New Battery
My Ride: Expected delivery on 15 Jan 2007 525I Olivian Green, Beige Interior, PP, CWP, PDC, SP, Rear shades,heated rear seats, Ipod fitted, Nav, Oem Rims 166, Xenon Lights, Wood grain package, illuminated door sills
Same problem here with some creaking when turing. I am going ot my dealer this weekend and inquire about it.
no creaking noice. BUt defintely had a rattle coming from thje rear parcel shelf when i hit rough parts of the road. Took it to the dealer, they put some velcro around the clips that attach the rear parcel shelf reasr defroster/vent. Defitnely dampened the rattle, but now I can hear the fabric rubbing once and awhile. Will mention it again when I take it in for service. There have been many threads regarding creaking or rattling from the rear of the car. Some have posted DIY for the parcel shelf rattle, other possible causes as mentioned are the door seals or the suspension....defitnely a few threads about nosies coming from the back of the car...GL...
**I was the one to suggest to the service tech to take a look at the parcel shelf (thanx to this forum). Prior to that all the tech wanted to do was tighten the back shocks and not check anything else. If and when you do take it to the dealer print out a few threads that have similar issues and fixes...it helped for me...GL
Update - insisted that the shop foreman drive with me to hear the creaking nose + chirping noise both from back seat area....in fact confirmed that it was comingfrom upper portion of back seat itself, he then readjusted and/or lubed the seat (I lost track of the actual work order sorry). For first time in 3 years, noise is gone! I can't f---ing believe it, it took 3 years to convince the service advisors that there was a problem, let alone take it seriously and do something about it besides saying its 'normal' or 'can't reproduce' or "sure its the door seals" even when I suggested it was not. anyways, just happy so far its gone, I hope this may help others that are experiencing same problem.
I had the noise with the rear seats as well. The noise is produced with the car flexes while driving. I believe some products you would use to clean the seats makes the leather on leather produce a cracking noise.
Using a leather paste, apply it any place where leather meets leather. Even removing the rear seat itself and applying the paste to the rear edge of the seat and below the seat back were the two components meet. Also, apply inside the seat cut outs for the seat belt restraint connectors. I have the split fold down seats, so it was applied between the seat backs and center arm rest.
Some liquid cleaners work temporarily, however the paste doesn?t dry and keeps it quiet.
