In a mode to change rear brake pads need help
I need to change the rear brake pads as I am reaching 60K in my car with service light coming on soon.
I never done that before but I am very good following instructions.
I have the following questions:
1-What part do I need beside rear pads and sensor?
2-Do I need to change the rotors and disk or more than likely they are fine? If most of the time is required what part do I need?
3-How do I rest the service light after pads and sensor replaced? Is that through I-drive or I have to do some other sequences?
4-Anyone has a step by work instruction (Or any link)with pictures that I can follow?
5-Any place that I can purchase the original parts directly cheaper than dealer?
Thanks,
Thanks,
DIY guides can be found here:
http://forums.5serie...album&album=213
in terms of part numbers: you can use realoem.com to get everything you need...
for OEM parts, check: http://www.getbmwparts.com/
brake reset procedure: https://5series.net/forums/topic/535...90#entry563090
My Ride: 14 550i
If you're interested in after market brake parts and pads let me know they are a lot cheaper than OEM. I've sold a ton of sets on this forum and haven't had issues.
Michael
Owner
Acute Performance
Michael
Owner
Acute Performance
TexaZ3
05-06-2015 09:54 AM
