That is not a bolt hole (at least not for that side). And you can tell no bolt goes in that side because there is a triangular strengthening beam so close to the hole that no bolt head would be able to clear it.
The pic below has a slightly different transmission but you can see that on the opposite side of the hole is an external torx bolt that secures the transmission bell housing to the engine oil pan. I guess the manufacturer considered it easier to just drill the hole all the way thru.
