Misfiring and brakes fade. Please help!
#31
My Ride: 05 530i M54
Model Year: 05 530i
Engine: 3.0 M54
I've never seen some one luck up and get the same values on energy. I guess that's better so you won't be confused. The flow values are definitely how I described it though. They were programmed lower than the DME read value which is a dead giveaway. 1.3 is the lowest it reads and I've never seen an injector lower than 2.xx. Also you had 3 that were coded over the max value which is 3. Cylinder 6 looks like it was the only one coded correctly. Either way they do need to be coded correctly and I hope what I've explained helps out.
#32
bimmerdad74 (08-11-2023)
#34
Model Year: 05 530i
Engine: 3.0 M54
Ok I had to rethink this and something escaped me since I haven't had to deal with this in a while. Do you have an index 11 or 12 injector on cylinder 6 and index 10 or below on cylinders 4 and 5? When you said you updated to 12's was that for all 6? Right now your values do not look like index 12's. Cylinder 6 is the only one indicating it's a 12
#35
#36
Model Year: 05 530i
Engine: 3.0 M54
A while ago people were selling knock off index 11/12s and you could tell by the coding numbers they were not correct. I don't know just trying to get you prepared for when you get your DME back. I think after the DME and the injector/coding issue is resolved you will be fine. I think the most import part is looking at those injectors and figuring out if the numbers are coded correctly. If they are then you need at least cylinders 4 and 5 changed to index 11/12 injectors to get it running back like it should.
#37
![](https://cimg5.ibsrv.net/gimg/5series.net-vbulletin/2000x1504/e21a344b_2aa6_4595_9a4e_5be73fce0d0d_4cbd1c788f5222aef3cc79f4d7b9d0e2656a3e0e.jpeg)
heres cylinders number 3&4. I sent a message to the guy we bought them from. I’m guessing they’re not open on the weekends.
#38
Model Year: 05 530i
Engine: 3.0 M54
Yea I've never seen index 11/12 with flow values so high other than with the china knockoffs. Hell not even index 1-10 are that high. I'm not saying they don't exist I'm just saying I've never seen them and I've done a lot of replacements. What I'm seeing is you need 5 good index 11/12 injectors (preferably index 12)
#39
