What are your HPFP numbers? Are you sure you fixed all the vacuum leaks. What current codes do you currently have? Are you using OEM parts or cheap aftermarket parts?
I used mostly Bosch items. I believe rail pressure is hpfp pressure? I didn’t see any more smoke but I will test again. Misfire codes for all cylinders.
Turbos we’re also replaced 3-4 years ago as well as map and boost psi sensors with oem parts.
Your pressures are definitely too low. What codes are you getting? Are you tuned?
Misfire codes for all cylinders. No tune. Completely stock. Which side are you stating is low? Low or high side?
I looked at the high side. You're around 750 psi and that's way too low. You should be between 1200-1500 psi. Your LPFP is right on target at 72 psi which is what the DME sets it at
(Post 1618382)
Forget last question. Sometimes when I see the question I can answer it myself. 🤦🏽♂️
No luck with the hpfp. Starts at 179k hpf to idle at 5k. Hard throttle back up to 179k +. Is it possible that a leaky brake booster may cause this?
