Misfire after hard acceleration
My Ride: 520xi
Hi guys. Has anyone experienced 29d2 misfire on cyl 6 after hard acceleration? Initially, I had a whole host of errors related to the vvt solenoids so I replaced both. Now the vvt errors are gone, but it is still running rough. I replaced all 6 injectors and swapped around the plugs and coils, but the misfire stays on the 6th cyl. If I start the car and drive easy, it runs great, no code. As soon as I floor it and accellerate through third gear, the check engine light comes on and it throws the 29d2 code. Any ideas? I would think wiring, but it comes and goes. 2007 530xi auto
My Ride: 07 530i LCI Msport
I had a similar issue, start with your coil packs, swap say pack 1 with 6 and see if the problem folkows. I ended up having 2 bad coil packs that had failed due to oil pooling in the spark plug wells from a bad valve cover gasket.
Engine: N54
Been trying to come up with some ideas for you but I can't get past this:
is it running rough or not? or is it only running rough when you get the misfire?
You replaced all 6 injectors with new ones?
Now the only issue left is it is running rough. I replaced all 4 injectors and swapped around the plugs and coils, but the misfire stays on the 6th cyl. If I start the car and drive easy, it runs great
My Ride: 520xi
The problem doesn’t follow the plug or the coil. I also replaced the injectors. No change.
My Ride: 520xi
runs smooth when I start and if I keep it below 1/4 throttle. When I floor it, it gets to 60 or so and then runs rough (cyl 6 misfire code) even at idle. Then I can turn the car off and back on and it is back to smooth idle with no code.
My Ride: 520xi
Valve cover gasket and plugs have maybe 10k miles on them. No oil pooling and plugs look good. Not wet or oily, which made me think the injector was fouled. If the coil was bad, there would be an excess of fuel on the plug.
My Ride: 520xi
Engine: N54
what is the history prior to this problem?
Ran perfect for a long time then suddenly this misfire?
My Ride: 520xi
Has run well for the last 6 months, but as we all know, these things are money pits. I have had it for 2 years 20,000 miles and I have had to do more to this car than any other I have owned. Trans valve body and all related mechatronics rubber, much of the cooling system starting with water pump, engine gaskets, all of the front control arms, started, front drive shaft......
I have had tons of bmws and Audi’s and this one has got to be the worst. BUT, it drives like a dream.
That said, I have impa and Carley, but I am not very good at using them. Any suggestion on how I can use these tools to troubleshoot this problem?
Engine: N54
If you are quite certain you have eliminated all possibility that it is not due to coil/plug/injector then
1) It is still something specific to that cylinder, such as
DME circuits that drive that coil/plug?
coil pack wires
valves
cylinder
2) Or it is not just specific to cyl 6 but seems like it is because it is the one that keeps misfiring first.
I would get it out on the road and force the misfire numerous times to try and determine if it is indeed always and only a cyl 6 problem.
coil pack wires
valves
cylinder
