Minimal power steering
Old Mar 14, 2012 | 11:26 AM
Gee_115's Avatar
My Ride: 07 550i Sports Package
Can someone please provide some input on this. I was trying that thing where you turn the steering wheel all the way left and right. I recently changed the Steering Column switch(SZL) There is some power steering but very hard. Anyway, when I turn the steering wheel all the way left or right to the point where it stops I here a sound like high pressure air is being released. If I let go of the steering wheel it stops.
Does anyone know if this is normal or what could be the issue? The resovoir is full. Also have adaptive steering malfunction.
Old Mar 14, 2012 | 11:55 AM
jgt's Avatar
jgt
My Ride: E60
Engine: N52
I don't know what the noise is exactly but it is normal when the steering wheel is locked out right or left.
Since you covered fluid already it sounds like the control unit or something specific to the active steering system is not functioning correctly...
Old Mar 14, 2012 | 12:03 PM
jgt's Avatar
jgt
My Ride: E60
Engine: N52
Now that I think about it it just sounds like whoever changed the SZL forgot to calibrate active steering.
Edit:
Just noticed that's what you were trying to do in the first place. I'd restart and try it out again.
Turn car on.
Start at center.
Turn wheel all the way left then all the way right.
Back to center and shut off.
Start up and all active steering malfuncitons should go away.
Old Mar 14, 2012 | 12:46 PM
Gee_115's Avatar
Edit:
Turn car on.
Start at center.
I actually changed it myself. I thought I was supposed to do it twice, can you confirm. Also, really appreciate the input.
Old Mar 14, 2012 | 05:13 PM
jgt's Avatar
jgt
My Ride: E60
Engine: N52
I believe it just once like I outlined. A quick search on google or here should turn up the procedure.
Kostadin Konstantinov
Jul 15, 2015 08:19 AM
CVTBenhogan
Jul 13, 2015 06:46 AM
ripley
DIY: Do It Yourself
Jul 12, 2015 01:49 PM
jeffandjaimie
Jul 8, 2015 05:48 PM
ST JAMES
Jul 3, 2015 07:04 PM
