Metallic vibration noise inside the dashboard ??
Old 04-16-2008, 12:54 PM
dwjrdto2000's Avatar
I have narrowed my buzzing/vibration noise down to the "Check" buttons on the edge of the signal lever. If I put my finger on those two horizontal buttons the noise stops. I have no clue how to fix it though.
Old 04-16-2008, 01:53 PM
good anti's Avatar
My Ride: 2004 BMW 525i Mtech front bumper, M172 rims, 2007 Audi Q7 4.2L
I know the sound as well.
i kept hearing it but couldn't find out where it was coming from. it sounded like it was coming from behind me at times and even from the dash board.
it was driving me crazy.
so one day i started veering for bumps in the road.
come to find out it was the metal wind deflector on the sunroof.
mine makes the most amount of noise when the sun roof is in the vent tilt.
this piece of metal resonates a lot. its just constructed too thin.
I'm thinking of putting some cushion tape on it to dampen the vibrations.
Old 04-16-2008, 09:19 PM
powers545's Avatar
My Ride: 2004 545, Sport Package, Steptronic, NAV, L7, PDC, Sunshades, Titanium Gray over Black, Bluetooth
May sound strange, but my vibrations came from the stearing wheel buttons when driving over uneven surfaces. Just place your hands on them when you hear the noise and see if that stops it - mine were replaced under warranty. Also, check the little corner vents just below the winshield - they will also vibrate.
Old 04-16-2008, 10:27 PM
atlvlk's Avatar
My Ride: 2004 E60 530ia Titanium Silver , Grey Dakota Lth , Piano black int trim... 2004 E60 520ia Jet Black , Beige Dakota Lth , Dark poplar wood int trim... 2003 Mercedes-Benz ML 320 AMG Obsidian Black , Grey Lth...
Post
Originally Posted by mrfva' post='562115' date='Apr 15 2008, 05:38 PM
I have (had) the exact same problem with mine. If I have the sunroof-liner open, glass closed I hear the glass on metal vibration noise. What I found out is that there's a metal strip that goes from left-to-right just where the glass goes in when it closes. When this metal strip is up when the glass is closed, it rattles. Put your finger up there and play with the metal strip, you can actually push it down away from the glass.
For now, I've placed a strip across the top of the metal strip to keep the glass from hitting the metal strip. I'll try to take pics tonight and post it.
-frank
Yes..
I found where the vibration sound comes from.
As you said it comes from the sunroof.The metal strip vibrates and hits the glas.
But the noise was coming like from the dashboard i did not think it may come from sunroof.
Thaks to everyone help me solve the poblem..I put cushion tapes between strip and sunroof and the noise goes off.
Old 04-16-2008, 10:31 PM
MatyB's Avatar
My Ride: 05 530i M Sport Sedan / Silver Grey
Originally Posted by atlvlk' post='562147' date='Apr 16 2008, 09:41 AM
I`m waiting for your pics. This sound makes me crazy..
Thanks .
Thank God i am not the only one who has this issue and is being driven insane by it, pictures pleeeeeeeeeeeeeeease!!!!!
Old 04-16-2008, 10:35 PM
MatyB's Avatar
what kind of tape did you use and where exactly did you apply it?
Old 04-17-2008, 12:39 AM
Bteljuice's Avatar
pictures please.my friend is having the same problem with his 630 convertible.so i dont think its the sunroof window lool.
Old 04-17-2008, 05:16 AM
good anti's Avatar
why do you guys need pictures?
open the sunroof.
the silver colored wind deflector in the front of the opening that runs the length of the opening is it.
how did i paint that picture?
not sure about the 630 convertible tho.
Old 04-17-2008, 06:12 AM
mrfva's Avatar
My Ride: .
Model Year: .
Here are some pics of th sunroof with the velcro (soft-side) for padding,
http://picasaweb.google.com/frankche...e/2004BMW545i/
Old 04-17-2008, 07:46 AM
beaker's Avatar
Very nice, mrfva - thanks. I'll try the same thing on mine to see if it works.
As an aside for others, instead of using velcro you can pick up sheets of felt tape that dealers use for this very purpose (you can even ask your dealer for some - that's what I did). It would probably work just as well, and blend in a bit better.
Quick Reply: Metallic vibration noise inside the dashboard ??
