Manual transmission in E60 (Diesel engines)
My Ride: E61 525dA
Originally Posted by rsyed' post='705218' date='Oct 28 2008, 11:05 AM
Dont the automatics always start in the second gear in D-mode???
My Ride: 2005 535D, Mystic Blue with Black Exclusive Leather;
Active Steering | Comfort Seats | Dark Poplar Wood | Front & Rear Seat Heating | Head-up Display | Headlamp Washers | Logic 7 | High Beam Assist | Media Package | Rear Electric Blind | Sun Protection Glass | Visibility Package
Originally Posted by Bedford530i' post='705094' date='Oct 28 2008, 03:17 AM
AFAIK, the 335d or 535d only come with automatics...
My experience in a BMW manual diesel is in my wife's 120d, as I said.
Originally Posted by Anzafin' post='705332' date='Oct 28 2008, 02:43 PM
Hey this worked quite well ! Thanks for the tip!
But does it give excessive stress to the clutch? After all, it's only that short moment to get the car in motion, like you said.
My Ride: E60 525d M-Sport Saloon M57N2 3.0d LCI
EXTERIOR: Jet Black, ///M-Aerodynamic Bodystyling, ///M-Rear Spoiler, De-badged, Gradual Tint Windscreen, ///M-Double Spoke 172M 19" Alloy Wheels (with non-run flats & space saver spare wheel) & ///M-Sports Suspension;
INTERIOR: ///M-Steering Wheel, Black Dakota Leather Heated Sports Seats with Electric Lumbar Supports, Brushed Aluminium Interior Trim & Anthracite Headlining.
To be honest I don't really have a problem with jerkiness when changing gear. I guess we all lift the clutch a little too quickly or slowly from time to time which may cause a little jerk, but on the whole I find my manual very easy to drive full stop.
I would certainly advise against setting off in 2nd gear from a standing start very frequently - this will certainly be adding unnecessary stress on the clutch and drivertrain - it was fitted with 1st gear for a reason - and yes the clutches are quite heavy duty and will easily take it in the short term, but it would take it's toll in the longer term.
I find when driving 'casually' in normal day to day traffic (excluding setting off on steep inclines) that the torque of the engine allows very early, relaxed (i.e. slow & smooth) gear changes, with changes made either at or just before 2000 RPM. For more spirited driving I obviously increase this accordingly. I also find 'flat out' driving with extra fast gear changes easy, the clutch feels so strong and precise when making a super fast change, that no sooner is the clutch quickly, and fully engaged, the car is immediately back surfing the next wave of torque. If ever I do make a 'jerky gear change' it is more likely to be somewhere between the two scenario's i.e. neither a fully relaxed, slow & smooth gear change nor a super fast change, but somewhere in between e.g if pulling steadily out of a junction then realising an approaching car is coming faster than initially anticipated, thus needing to make the gear change at slightly higher RPM's and semi-quickly - unexpectedily - having to change to the next gear - if that makes sense.
I actually find the gear lever throw to be very acceptable - it's no racing car, but it certainly ain't sloppy with a long distance between gears. However, I do have the 'M-Sport' model fitted with the M-Sport Gear Lever knob. When I initially took delivery of the car it had the wrong 'SE' type Gear Lever Knob fitted. This did seem to have a much longer throw between gears simply due to it's longer length. When the correct M-Sport lever was later retrofitted, the improvement was quite noticeable with reduced throw due to the shorter length.
Hope some of this helps.
My Ride: 535i 6-speed
Originally Posted by ADD' post='704935' date='Oct 27 2008, 06:37 PM
I usually start in 1st, and get to 2nd as soon as the car is underway.
This method worked good for me on my '95 525i 5-speed. It had 250K on the original clutch and was going strong when it was totalled ...no clutch or gear issues ever.
My Ride: Bmw 530d 2004
Great answers! Thank you all.
Does anybody know a chart where you could compare gear reductions (I hope you understand what I mean) between diesel and petrol cars. Manual of course.
Mihainede85
03-11-2015 09:45 PM
