Maintenance Work coming up
My Ride: 2007 ★ Alpine White
Time to have the maintenance work done to my car. It's hit 100k miles now. My service guy at BMW: "There are 2 oil leaks, one at the oil filter housing on the left side of the engine block & one at the transmission mechatronics sealing sleeve. The oil filter housing requires replacement of the seals & the transmission leak replacement of the mechatronics sleeve & pan. I don't recommend either repair be performed without a lift. The mechatronics sleeve a very specific repair measurement. If not placed correctly your car will not start. Of the 2 leaks your transmission leak should be repaired first."
Found an indi Certified BMW mechanic that is hooking up all this and then some for only $450. I already paid for all the parts down below. Repairs should be started this weekend or next weekend depending when all the stuff come in. I'm not paying $2300 to do all that stuff at a stealers + what it cost to do everything else. All parts are OEM. ZF and INA are original parts on the BMW
24-11-7-571-217 OIL PAN W (1) -- $133.97 ZF
24-11-7-552-108 TORX SCRE (24) --$43.44
24-34-7-588-725 SEALING SLEEVE (1) --$13.66
83-22-2-220-445 TF 1375.4 (6 liters) --$162
11-42-7-525-335 GASKET:11 (1) --$9.06
11-42-7-537-293 GASKET:11 (1) --$9.06
11-53-7-549-476 Thermostat + the screws (1) -- $77.15 INA
11-28-7-530-314 Mechanical Belt Tension (1) -- $77.93
11-28-7-628-650 Belt (1) -- $28.77
BMW Coolant (2 Gallons) -- $37.12
SAF-XO (2 liters) -- $40.00
spark plugs FR7NPP332 (6) -- $58.25
My Ride: 05 BMW 530I
Common issues with these vehicles. good thing you have an Indy to take care of it because I dont think anyone has the money to just throw the stealer a big tip.
My Ride: 2014 535 Alpine White
What model car do you have? just curious because my car hit 100k but it was serviced before i bought it with 95k
DavaiLave
08-02-2022 02:16 AM
chadillac2000
42
09-13-2017 11:15 AM
