MAF
#31
My Ride: '06 550i
'84 Nissan S12 Turbo
I cleaned mine a couple of weeks ago, and it seems to have improved the mpg...I forgot to reset the counter @ last fill up.....so i'll do that next time and see how many miles I get out of a full tank......
#32
if so how did you do that?
#33
My Ride: '06 550i
Originally Posted by parmblagan' post='769309' date='Jan 16 2009, 06:14 AM
did you take the whole MAF out and the and manage to get to the bit where the wires/sensors are? i mean did you manage to take the stalk bit out of the MAF housing.
This pic is from the link from the first page in this thread, so disregard the red arrow. I pulled the sensor out of the intake pipe without removing the pipe....
Once I pulled it out, I flooded it down in all of the holes and such with the crc maf cleaner. The "hot wires" are exposed on mine, so I was able to spray them too with no probs.
Here's another pic from the first page...so again disregard the red writing/ arrows. Just a reference of where the hot wire sensor is located on the maf sensor, which is the little paper clip looking thing...
The spray dries fast, but I let it sit for 20-25 mins to make sure it was dry inside. Then I just installed it back on in the reverse order.
#34
My Ride: 14 550i
the 530d have a different engine configuration. i believe that's not how his MAF is attached.
Originally Posted by ktlocklear' post='769407' date='Jan 16 2009, 08:21 AM
On mine (550)....there are 2 hex screws that hold the maf sensor to the housing, which are under a clam shell cover. I unclipped/ removed the clam shell cover, then unscrewed the 2 hex screws, unplugged the harness then pulled the maf sensor out of the housing.
#35
My Ride: '06 550i
Don't know then...the maf sensor should still be mounted/ screwed into a housing somewhere between the air box and throttle body.
#36
i have managed to get to it and take the whole MAF sensor housing out, my problem is i cant take out or sholud i say expose the wires/sensors to get a good clean.
the picture below shows the MAF and in the red box is the area that i can remove to expose the wires, which are shown in yellow.
any help would be great
#37
Originally Posted by parmblagan' post='772457' date='Jan 20 2009, 03:35 PM
the MAF on the 525D is different as shown in the pics before.
#39
Originally Posted by myfootsmells' post='767883' date='Jan 14 2009, 07:37 PM
i need better angles please especiall of one looking into the tube
#40
My Ride: 14 550i
ahh okay. have you noticed any improvement since cleaning?
Originally Posted by parmblagan' post='773351' date='Jan 21 2009, 04:15 AM
i have put the MAF back in now, but taking pics from a different angle are difficult as its very difficult to see the wires or senors.
