M5 rotor upgrade
Hi I have a 2009 535XI just wondering if the E60 M5 brake rotors will fit for my car. I have upgraded 19 inch Beyern wheels. Also thinking on replacing the exhuast system with the M5 exhaust will that work? Thanks.
My Ride: 05 545/6
the exhaust you're out of luck for sure- the M has the battery in the center of the trunk, with no spare tire, so there's plenty of room underneath for the right side mufflers. on your car, not so much. there are quad-pipe exhaust solutions out there that will fit, but the stock m5 cans will not.
Originally Posted by 545felix' post='922030' date='Jun 24 2009, 07:31 AM
you can't just do the rotors, you'd need the calipers as well. but since you have an xi I think you're out of luck- the hubs (and thus the offsets) are completely different, so I don't think the M units will bolt up. they will fit the RWD cars, but not yours.
+1000, you can check with user Rizbel who already did this swap on his e60 (non-Xi) and see if he knows, but I think the above is correct and you are unfortunately out of luck.
Originally Posted by NeRwEEzy' post='922122' date='Jun 24 2009, 09:16 AM
as another option, we carry some OEM-sized rotors. most popular ones are the ones that are custom drilled and slotted.
Good point, drilled rotor and some caliper painting would set your brakes off nicely and cost less than 10% of a BBK, definitely PM Nerweezy
You cannot just use the m5 exhaust-not tuned for your car's engine and thus wont maximize your power. It is tuned for a specific engine although since you have TT you can get away with larger diameter exhaust but not sure how big the M5s exhaust pipes are
umnitza
09-02-2015 11:28 AM
Florida2002m3
09-01-2015 10:59 AM
