m5 LSD
Old Jan 18, 2013 | 01:15 PM
boosted5's Avatar
Default m5 LSD
Anyone attempt to swap an m5 differential into their regular 5er? ex 535i LCI ..?
Old Jan 18, 2013 | 01:35 PM
pjinca's Avatar
I pulled the following answer from another forum, they are talking about a 545/550, but the same should hold true for your 535 (sounds like it's easier to just get the Quaife, a few members here have done that already):
"I have thought about doing this as well. Here is what I know:
The M5 LSD differential is slightly larger in width and length, than the 550i stock differential. In the 5 series, BMW uses a modular setup for the Differential, Axles, and driveshaft. The following would be needed:
1) M5 LSD which could possibly be obtained at bavarian auto recyclers from a wrecked M5
2) Rear Driveshift (The driveshaft on the 5 series is two-piece with a joint in the middle. The rear driveshaft on the M5 is shorter than the rear driveshaft on the 550i)
3) New MS Axle shafts (these are also shorter than the 550i and should bolt directly to the axle hubs on each wheel with no issues)
The car will probably need to have a reprogramming for both the transmission and the DSC."
Old Jan 18, 2013 | 01:47 PM
Rizbel's Avatar
My Ride: 545i Sport
Engine: N62
Originally Posted by pjinca
... sounds like it's easier to just get the Quaife, a few members here have done that already): ...
I agree with John on getting the Quaife ATB limited slip differential.
Old Jan 18, 2013 | 03:34 PM
boosted5's Avatar
Any links to these threads ? I have a 6mt, I don't think I would need to reprogram it. If it bolts right on that would seem like a cheaper and better option than the Quaife.
Jul 3, 2015 03:06 PM
LSD Motorsports
Group Buys
Apr 18, 2015 11:49 PM
jcolley
Mar 17, 2015 09:15 AM
LSD Motorsports
F10 Discussion
Apr 7, 2014 07:04 PM
bun[z]
Mar 14, 2010 11:05 PM
