m/s mode does not work...
Old Jan 12, 2014 | 08:30 PM
Bimmer5project's Avatar
My Ride: Sapphire Black 07 530i non-sport 7000k Angel Eyes 6000k HID Xenon adaptive turn Head lamps and Fogs, Clear LED Turn Signals front/back and side markers. Clear bright license plate lamp. Full interior lighting upgrade. Coding: daytime angel eyes, auto windows up, and digital speedometer. (Thanks to John at Motorcepts.com) OEM Tinted LCI Tail lights (Thanks to David at http://www.luxmotorwerks.com Oem Mtec rear bumper with diffuser and M5trunk finisher Debadged! The best paint work! (Thanks to Desimone BMW) 20x8.5 +18 20x10 +25 Concept One RS-8 Black Machined Chrome Lip V6.1 cables (Thanks to Bruce Miranda) Nitto Invo tires 285x30 R20 - 245x35 R20 Discounttire.com Vac Motorsports ecu chip upgrade, and fender roll http://vacmotorsports.com/ wish list: Rieger Front bumper Hamann side skirts Custom quad exhaust Rpi Ram air intake scoop M5 SMG shift knob KW Variant 3 suspension Brembo Big Brake kit LCI Heads Tints BMW M5
Default m/s mode does not work...
any idea what can cause the manual shift mode to not work?
It drives fine in auto, but nothing happens when I push it over to M/S, and I usually use it all the time.
so sad
07 530i
Old Jan 13, 2014 | 07:18 AM
Hyper_545i's Avatar
My Ride: 545i
Engine: N62
I have heard the wires under the shifter getting crimped, disconnected or torn. I have seen many posts on this on the E90 Forum. Not sure if this is the same issue or not. Have you taken a look under the shifter to see if anything is disconnected?
Old Feb 14, 2014 | 09:55 AM
Default Manual Shift mode not working
Sorry for the delayed response but yes, you're right! looks like a torn wire that engages m/s mode.
Driving in auto mode hasn't been the most exciting driving experience lately, but saved me a lot of gas
I would like to eventually repair this on my own, but wouldn't know where to start.
can someone help me out?
https://5series.net/forums/attachmen...1&d=1392403981
https://5series.net/forums/attachmen...1&d=1392403991
TIA
Attached Thumbnails m/s mode does not work...-photo.jpg   m/s mode does not work...-photo-1-.jpg
Old Feb 15, 2014 | 08:29 AM
twh's Avatar
twh
My Ride: 2006 BMW 530xi 6MT
Engine: N52
Kind of hard to tell from your photos. Do you see the green wire completely cut? If so, best repair is soldering in a small piece. You'll need to remove some of the electrical tape to get at the one side of green wire and remove insulation from both parts. Slide on some heat shrink tubing. Splice in a small piece of bare wire and twist the green ends over the bare wire. Solder it. The slide the heat shrink tubing over it and use a hair dryer or heat gun to heat it up and shrink the tubing. Use electrical tape to tape everything back up and especially whatever the rubbing part that caused the severed wire in the first place. You should be also to find some YouTube videos on the soldering process.
Old Feb 19, 2014 | 02:38 PM
Yes the green wire is totally severed due to my bad habit of switching in and out of m/s mode.
Thank so much, its a pretty tight squeeze but I may be able to get to those wires. I will attempt to do this, and let you know.
I'm really good with tweezers.
Old Mar 30, 2014 | 07:03 PM
TIA
I finally have the time to work on soldering these wires in the gear shifter. I think it would be easier to remove the whole shifter assembly but cant figure out how to do it. Anybody know of a descriptive DIY that shows how to do so? better yet how to solder these wires together?
The wires are tiny and I know if I screw this up, I'm screwed!
I probably would have to replace the whole wire that probably runs through the whole car.
Old Mar 31, 2014 | 10:25 AM
twh's Avatar
twh
Engine: N52
Looks like you have room. Here is how I would proceed if it was on my car...
Carefully cut open the plastic conduit an inch or so. That will expose the wires.
Feed a piece of heat shrink tubing over the wires to be fixed and push it back far out of the way.
Trim off half inch or less of insulation on each wire end.
Twist the wire ends together.
Solder them.
Feed the heat shrink tubing back over the soldered joint.
Use a heat gun or hair dryer to shrink the tubing.
Get some split corrugated plastic conduit from the auto parts store and put it over the existing conduit and the wires that have been exposed.
Wrap it up with electrical tape.
Old Mar 31, 2014 | 12:39 PM
Solder them.
Thanks for your help man. I wish I woulda got this message earlier... I totally f'd it up by taking off about an inch of wire. I've never soldered anything before so I wanted to take the whole thing out to get better access. Here is the current state it's in . Hope I have other options. http://
Old Apr 1, 2014 | 04:54 PM
twh's Avatar
twh
Engine: N52
There is enough room to work there without removing anything. If you haven't ever soldered anything before, maybe this isn't a good first time. If you really want to do this, you need a soldering iron and some solder. You need some solder made for electrical wiring. You need some heat shrink tubing. Looking at your video, you'll need to cut away some of that friction tape at the left to expose some of the left side green wire. You probably need to splice in a piece and cannot do it all with what remains. That will require two soldered joints. You can find some how to solder videos on YouTube.
I'm not a big fan of low end crimping tools as they don't make the greatest bond, but that would also work. The joint isn't subject to great stress and environment. You can get something at Home Depot or the auto parts store. You'll need a barrel connecter and a crimping tool. No soldering required. You need a barrel connector like this to join the two ends together. Something like the two on the left here:
https://dlnmh9ip6v2uc.cloudfront.net...591d000000.JPG
Vman33
Mar 14, 2022 04:43 AM
ilovemye60
Nov 10, 2015 07:48 PM
Jiawei Zhao
Oct 21, 2015 08:46 PM
1BFL
Sep 28, 2015 11:10 AM
e60gg
Sep 3, 2015 05:26 PM
