low tire pressure warning
thanks for the heads up--i will check with a tire pressure gauge later this afternoon. this is the first error/warning message i have gotten from my car and i have never had to reset idrive for anything, which is why i asked what to do. also i do not have run flats.
as for the search function, i find it pretty cumbersome on this board. it has been usually a very laborious process to search and find more than 1 relevant historical post to address whatever problem i am searching for an answer to. so just kind of by default i figure i will get a useful answer in a response quicker than i will if i attempt to search for it
![Doh](https://5series.net/forums/images/smilies/imported/doh.gif)
use the advanced search function rather than the general search tool bar, in that you can limit your searches to specific areas such as the DIY section, or part, mods, accessories section
also helps if you link works together with a "+" or just surround your term/phrase with quotation marks: "xxx xxx"
